Window text not showing up
mukster
Using Archicad 17, Mac platform. Suddenly the window labels are not showing up, and neither is the window. Just outlines of where the hole is (in the plan view). They show up in 3D and in the elevations, just not the plan views.
4 REPLIES 4
David Maudlin
mukster:
Check Model View Options > Options for Construction Elements > Window Options. Also confirm that both the Wall and Window Floor Plan Display is set to Symbolic. Also check their Renovation Status. If those don't work, post some screen shots, maybe someone can identify the issue.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
mukster
Thanks - that worked. Don't know why it kicks things into different settings randomly.
rocorona
or people clicks things into different settings randomly...
just kidding!
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Model View Options settings are saved with Views so these settings may change when you activate a saved View. You should check the MVO settings your Views are saved with, that may be the problem.
