Window top&bottom
Hey everybody,
Im looking for a shortcut for an a,b values of a window.
Unfortunately, i can't find the command that responsible on those parameters in the work environment.
I know only the shortcut b that changes the windows vetically distance from the slab.
Is there any shortcut already? Or how can i create that command in the work environment.
Sincerely,
Yagil
1 REPLY 1
I think there is no way to set shortcuts for these fields in the Work Environment. Dialog. There are several shortcuts that work in the Info Box, including T for Top Elevation and B for Bottom Elevation, but there are no shortcuts you can assign for the Width and Height fields and Doors/Windows.
