2021-12-13 03:01 PM
Hi guys, I haven't used to much the windows schedule so I'm a bit unfamiliar with it.
Could you please let me know how I can remove elements that I don't want in the schedule.
For example, I have a lot of wall niches of various sizes witch are still classified as a windows by Archicad and I don't want them in the schedule.
Thank you.
Solved! Go to Solution.
2021-12-13 04:06 PM
Chris_Lz,
It would have been more relevant to share the previous screen which explains how you call your elements. I invite you to exclude the elements of library having for name "Wall Niche rectangular 22".
2021-12-13 03:41 PM
Hello Chris_Lz,
Tell us how you call your elements into schedule then we will be able to tell you the best way to exclude some of them.
2021-12-13 03:56 PM
2021-12-13 04:06 PM
Chris_Lz,
2021-12-13 04:09 PM - edited 2021-12-13 04:12 PM
Thank you so much, I've managed to do it.
2021-12-13 05:43 PM
There are several ways to organize the scheduling of windows, (or almost any object for that matter), by employing the element ID is a judicious manner. Windows can be identified by type; W01, W02, etc. The scheme for the schedule can control the data that is displayed. Hint: On renovation projects, I sometimes use the element ID to be "E.T.R." or "DEMO". Those ID's can then be excluded from the schedule scheme. You can even use the schedule scheme to count the number on instances of a particular window type...
2021-12-13 06:01 PM
2021-12-13 06:09 PM
You are welcome! Since I have not installed Archicad 25 yet, I will not confuse the troubleshooting process of the window dimensions. I am confident a Graphisoft Archicad 25 expert can assist with the dimension display issue...
2021-12-13 06:51 PM
Chris_Lz,
Did you check the Dimensions settings ?
Did you uncheck and then check the Dimensions option about these windows without dimensions ?
Did you ajust schedule dimensions by the "3 points" on the left top of your schedule ?
2021-12-13 07:32 PM
Hi Christophe, already tried all mentioned by you.
I have managed to solve it by removing the individual rows with Height and Width and putting instead one row of the W x H window criteria. I don't know why it works like this, but it does.
