Windows Schedule
Hi! I have a question, for the windows marker in the floor plan, instead of sill hight it possible to show header hight? Thank you.
And for the ones are in vacation, have the best one.
5 REPLIES 5
I see only Sill Height option in the default Window Marker.
It is possible to do but you would have to modify the GDL Object.
Hi ! Laszlo thanks for your answer, did you know wich parametres in the script of the archicad windows I need to modify?
Thanks
It is not as simple as modifying a single line in the script.
If you don't already know what to do based on the above, it is probably too hard for you to try.
You would have to modify a macro called from the Master Script of the Window Marker. Yu would probably have to create new parameters so you can decide whether you want to display the Sill or the Head. If the choice is the Head, its value would have to be calculated.
Also, the Interface Script of the Element would have to be modified so that the custom interface also displays the Head option.
So this is several hours of work, even if you know GDL.
Thanks, it is to complicated.
But I am asking why graphisoft don't include this parameter in original part?
May can be a wish
Yes, this could be a wish.
But honestly, I have never had a job in which it was a requirement to show the Head value instead of the Sill. Maybe in other countries it is different...
Learn and get certified!
