Project data & BIM
Work done in teamwork is not showing up in exclusive access.
Its annoying to go back and forth from teamleader to teamleader w/ exclusive access just to change the layer combinations, pen settings, etc. but i noticed that some of the drawing names made in layout book as teamleader is not showing up in exclusive access. I made sure that the layers were turned on but still nothing. Has anybody seen this problem occur or am i just seeing things. its making me alittle worried that if just a simple text is not showing up, then what else could be missing.
4 REPLIES 4
TomWaltz
I've not seen the problem you describe, but why would you change to exclusive access to edit a layer combination or a pen setting? You only need to be Team Leader for that.
Tom Waltz
oh i guess i am seeing things....yeah and your right about being teamleader. sorry i just panic'd. thanks again
Has this changed with AC11? I cannot seem to change the layer combinations when signed in as Team Leader (Not exclusive access).
Link
Attached is a list of modification privileges for teamwork projects in AC11. It is not guaranteed to be 100% accurate or complete, but it should list most common attributes & settings.
If you want a PDF copy of it, please PM me with your email address.
Link.
Learn and get certified!
