X Marks
Daniels41
Hello Guys I need some help I will atach I screen the thing is that , How can I delete those X on the stairs and around all the section view. Any advice ?
Noemi Balogh
I think these are all hotspots. Select the hotspot tool then ctrl + a / cmd + a and delete them.
Noémi Balogh
Community Expert, Admin
Noemi Balogh
Noémi Balogh
Chris Grantham
The number of hotspots around the section also tells me that the section is no longer live and is probably 'independent'.  You might want to confirm that you did not inadvertently delete the section marker, but retained the view.  This might also be what you wanted as well.
16" MacBook Pro M1 Max
Mac OS 12.2.1
ArchiCAD 25 Build 6005
