Zone relations request
rav668
I was trying to use request for zone relations for my door stamp, however variable that I need does not work. I paste here two relevant lines. [AC22] Thank you in advance!
qqq = request ("Zone_relations", "", asd1, asd2, asd3, asd4)
text2 0,0,asd4
add
 asd1="": asd2="": asd3="": asd4=""
before request
Piotr
6 REPLIES 6
rav668
It works but warning pops up and says "Uninitialized variable"
rav668
Adding this variable to parameters solves problem with warning but what is the point if you don't have to do it with other requests...
add
before request
Piotr
rav668
Thank you Piotr for your reply. I think these variables are already text. Am I thinking right? Is this formula: asd1="": asd2="": asd3="": asd4="" making variables string to text?
Best regards,
Rafał
You have to declare the variables before they are used (either as parameters or by script as I showed)
Piotr
rav668
Thank you for sharing.
Best regards,
Rafał
