2008-09-29 01:17 AM
2008-09-29 02:05 AM
2008-09-29 08:20 AM
Braza wrote:You could do this... but it is far from ideal.
Hi Angus,
Be sure that the reference lines don't touch each other...
Hope it helps...
2008-09-29 07:25 PM
Laura wrote:And don't forget that you can select the wall you want to trim/extend and then while the wall tool is active you can CTRL click on the edge you want to trim/extend to.Braza wrote:You could do this... but it is far from ideal.
Hi Angus,
Hope it helps...
Create two layers, each with a different Intersection Group -- walls placed on these two layers will not intersect with each other. For instance, we usually have two different layers for masonry vs. stud construction -- also a must when working with new vs. existing construction vs. demolition.
2008-09-30 03:19 PM
2008-10-05 11:02 PM
Barry wrote:thx barry and allLaura wrote:And don't forget that you can select the wall you want to trim/extend and then while the wall tool is active you can CTRL click on the edge you want to trim/extend to.Braza wrote:You could do this... but it is far from ideal.
Hi Angus,
Hope it helps...
This stops the wall automatically trimming to the other wall's reference line if you don't want it to.
