auto join together of wall
i know archicad is very intelligent that it connect walls automatically when they meet together.
what if i want to put them together but without this connecting function?
i'm making a corner wall, but i don't want them to join together
5 REPLIES 5
Hi Angus,
Be sure that the reference lines don't touch each other...
Hope it helps...
Laura Yanoviak
Braza wrote:
Hi Angus,
Hope it helps...
You could do this... but it is far from ideal.
Create two layers, each with a different Intersection Group -- walls placed on these two layers will not intersect with each other. For instance, we usually have two different layers for masonry vs. stud construction -- also a must when working with new vs. existing construction vs. demolition.
AC26 US (5002) on Mac OS Ventura 13.5
Laura wrote:
Braza wrote:
Hi Angus,
Hope it helps...
And don't forget that you can select the wall you want to trim/extend and then while the wall tool is active you can CTRL click on the edge you want to trim/extend to.
This stops the wall automatically trimming to the other wall's reference line if you don't want it to.
__archiben
if you want to get complicated, there are also wall skin priorities to consider . . .
http://archicad-talk.graphisoft.com/viewtopic.php?p=82488#82488
(works for me . . )
~/archiben
b e n f r o s t
Barry wrote:
Laura wrote:
Braza wrote:
Hi Angus,
Hope it helps...
thx barry and all
this method is much easier for me
