Design forum
auto parameters
I have a problem. I would like to create an object, which has “n” identical units, which are the same macro units with several setups opportunities. I would like to solve this case, with newparameter, like this:
for i=1 to n
	newparameter "nwpar_1", "RealNum", 1, 1
next i
Can anybody help with this? Because I tried with only the "newparameter" command, but I can't see any new parameters created.
From reading the GDL Reference Guide I get the understanding that the NEWPARAMETER command is specific to Backward Migration Scripts of Library Parts.
So it is not possible to create a new parameter for a library part from a GDL script, not with this command or any other command.
You have to create all parameters you want to use in the Library Part Editor Dialog.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Thank You!
Didn't find the answer? Start a new discussion
Labels
