array parameters, HELP!
hello everyone, can you help me with this script? i have 7 rows on X, and 6 rows on Y, can i have 13 values for "ex" parameters?
In some situations while working in AC16 elements such as slab will be hard selected to be enlarged or reduced except clicked shut layer to another element and this element also occur when the slab has been piling up over the roof or beam or slab wit...
As the subject says, how do I get to see that in plane view? I used Archicad 15 for a while some time ago, and I remember beeing able to see for instance insulation within the wooden composite wall when beeing in plane view. In 16, however, I haven't...
Hi, I want to copy the walls and columns from ground floor plan to first floor plan in version 14.unfortunately, when I go to design menu , the EDIT STORY LEVELS is inactive.Any idea how can I copy the walls and columns from one level to another?(ple...
This Story(underground) on the picture needs to have doors and windows but floor keeps getting on its way?I dont get it ?is it because this floor is underground or something else?Is there a way to fix it?Thanks for helping noob
In renovation tool, am adding new skin (4" insulation with sheathing) to existing 2x4 frame. Insulation skin is drawn as "new" construction against edge of "existing" wall. When I place a window in the new skin layer however, I also need to cut an op...
I have a problem in my archicad, i was working in a project but the 3d window froze and i can't move the view and it looks as it is all zoomed in. the rest works normally but the 3d window doesnt, how can i fix that ?[/img]
How can i make the window marker look like this: (see attachment). I have to make it look like this because this is the format they use at the studio im working. Thanks![/img] its width X Height over Sill
Here I have an issue with referring to some object file. We have received an library file from our client in Japanese version. But when we loaded these library files in the project, We got an error in the dialog box where the text in the parameters a...
is it possible to use complex profiler with barrel vaulted roof, to create an extrusion to make a roof like this? i've done barrel vaulted roofs before in archicad but not sure if it is possible to do one with an extrusion?
User | Count |
20 | |
9 | |
9 | |
8 | |
5 |
