3D Window does not work
When I select the 3D window (going from 2D to 3D) all that I get is an editing plane (with x,y,z axis) but no 3d representation of the building. Can someone please advise ? Am using ArchiCAD 16.
Hi, I've tried to open 4th file without closing the other 3 files but the archicad 15 didn't open and didn't fail. Is it possible to open more than 3 files with Archicad 15? Thanks for your help. Erbug Architecture
Hi, I downloaded a .lcf object folder from internet, when i add into my library from library manager, ut it can't find from my embedded library. Anyone can help?? Thanks. Cheers, Hazel
Can anyone help for solving cut (scissors symbol) element operation in 3D for Archicad 16 not perfectly working ??
I was at work today doing some very tedious line work (2D). I wanted all the line work to be on the same layer, however, the default setting I set for the layer of the line would not stick. Sometimes two or three times it was okay. After that it defa...
I complained to my colleagues that, in version 16, the 'Open File' option on the menu bar leads to a second 'Open File' menu - which seems like an unnecessary step. One colleague said: 'But it was like that in release 14!' while another didn't know w...
I know glob_context= 4 is for section/elevation, but is there anyway for an object to know that it is being cut in section/elevation. I have objects that I want to display more detail if they are being cut. If they are not being cut, I want to conser...
Hi All, First of all, i'm using the dutch archicad 15 library. When i use the Oval Window, there is a problem with the window-object when i use a reveal. When i don't use a reveal then the window is drawn perfectly. On the picture below, you can see ...
Seems the zooming in (in 3d) on a morph object (works ok other objects etc.) is normal until I try to get close to see details of what I'm doing, then it jumps me past the point of my object. I zoom out and try again and keeps happening. But sometime...
Dear All, During BIM Components Registration process a number is generated. I am asked to copy it into "ArchiCAD's Registration Number field". Where to find this ArchiCAD's Registration Number field? In ArchiCAD itself, on bimcomponents.com or myarch...
User | Count |
23 | |
11 | |
10 | |
9 | |
6 |
