Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 7560 Views
  • 126 replies
  • 16 likes
Locating pln file for published Module
Does anyone know how to find the details of the pln file from which the hotlinked module comes from? (e.g. I am working on a legacy project that has a module hotlinked into the file which needs changes but have no idea which pln file it comes from). ...
Anonymous by Not applicable
  • 2624 Views
  • 6 replies
  • 0 likes
extending composites
Hey everyone, somewhere i saw a video explaining how to adjust skins in composites so they can overlap other elements. like if i had rigid insulation skin on the outside of a composite wall and i wanted that skin to hang down from the bottom of the w...
  • 1710 Views
  • 4 replies
  • 0 likes
Why is this so hard?
I'm trying to create a detailed object (woodwork) by adding dowels to show construction method. I've created the profiles with OBJECTiVE, but I didn't realise that you cannot SEO on these tools. I've tried a complex profile (wall) but because part of...
  • 3038 Views
  • 4 replies
  • 0 likes
Renovation Newbie
This is my first go project using Renovation Tool. I really like the setup, but all my textures are changing to blank colors (not referring to demo/red or new/green items). The roof and the top of my chimney is showing the texture. So basically, only...
Red by Enthusiast
  • 825 Views
  • 0 replies
  • 0 likes
Moving a Wall
Sorry about the novice question. I've drawn 2x vertical walls and would like to move wall 2 (which is on my my right) a set distance from wall 1, lets say 5m or 5.2m etc.... I come from a Revit background so to do this in Revit I simply select wall 2...
  • 6522 Views
  • 5 replies
  • 0 likes
Shift locking polar axis issue
Is anyone else having issues with locking x or y coordinates in 3d when moving items? I notice it more when selecting a node of a slab and aligning it with another building item.
  • 5525 Views
  • 4 replies
  • 0 likes
Adjusting window sidelight parameters
Hi, I'm trying amend a window with sidelights either side. I know the door leaf size (762 x1981) so I set this in the window settings. I then want to be able to drag the sidelights to the correct size whilst retaining the door leaf size. At the mo, t...
  • 1317 Views
  • 1 replies
  • 0 likes
mater of priorities?
hello, can someone please take a look at the attached image and help me with the issues i have? as you can see i have three items that intersects. a slab composite profile, awall composite profile and a beam custom profile. the problems: 1)the insula...
  • 1300 Views
  • 2 replies
  • 0 likes
