My first GDL object!!! Tile object
Hi, i have made my first GDL, it's a object that realize tile objects. I have made a videotutorial explain how it works. www.youtube.com/watch?v=A3mfHPgx6IY If anybody can probe it as "betatester" can mail me.
I am trying to place some skylights onto a roof made up of two roof objects stacked on top of one another. i'm trying to create scissor trusses. i can't seem to get the skylight to cut through both roofs. i've extended the trimming bodies but that di...
I am trying to represent a Window trim that is accurate. The trim is to have and Exterior Sill and Apron (Wish Apron could be adjusted) and and Interior Sill (Stool) and Apron. Usually we only have interior Stool & Aprons and it seems to work fine fo...
Hi, I need to create several gothic style windows with slanted reveals and jambs both internally and externally for a church which requires modelling any ideas? thanks Nigel
Hi folks, I posted a subject about 3D Documents, explaining how to create and its behavior. Those who want to see, just enter in: http://noletoblog.blogspot.com.br/2012/03/eficiencia-dos-documentos-3d.html Moderators: I hope my last threads created, ...
Hello, I have a problem with the REQUEST Zone_Relations It's working fine in the 2D script but not in the 3D ?! I use archicad v15 main script : nomCat = "" codeCat = "" nomZone = "" codeZone = "" nomCat2 = "" codeCat2 = "" nomZone2 = "" codeZone2 = ...
I started a new project as normal, added a map (jpg) and resized it. Started drawing above the map. When I start project I like my cut fill on the walls to be black, foreground fill, but in this project the walls are only showing as lines (inner and ...
What is the best way to create an enlarged detail from a section that was generated from the model. Thanks. Tom
Hi all, I have a sky light (see attached image) and currently its slope is following the roof pitch. Although the roof is flat, my understand is that it requires a roof pitch set at 0 degrees. Is there a way to rotate the sky light 90 Degrees? and mo...
Hello, today my movement of objects is constrained/locked only in the y direction. How can I get it to move objects anywhere (ie x as well). I must have pressed a shortcut somewhere and locked it. Help. Michael
User | Count |
24 | |
7 | |
6 | |
5 | |
5 |
