Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 9394 Views
  • 127 replies
  • 19 likes
Stairs entrance
Hello everyone! I have one short question, i cant figure it out, how to switch stair-entrance sides.. by that i mean, i want that the stairs will start on left side and end up on right in upper story. (just switching sides from right to left) like it...
Anonymous by Not applicable
  • 1501 Views
  • 2 replies
  • 0 likes
urgetnt!!!
hello, how can I change the color of every thing in the 2d page all at once .I want everything in my 2d windoe to be black except 2 or 3 things I choose...what is the fastest way?help me out plz
  • 893 Views
  • 1 replies
  • 0 likes
array parameters, HELP!
hello everyone, can you help me with this script? i have 7 rows on X, and 6 rows on Y, can i have 13 values for "ex" parameters?
Cosminn by Contributor
  • 931 Views
  • 0 replies
  • 0 likes
Accuracy election slab element in AC16
In some situations while working in AC16 elements such as slab will be hard selected to be enlarged or reduced except clicked shut layer to another element and this element also occur when the slab has been piling up over the roof or beam or slab wit...
  • 10744 Views
  • 17 replies
  • 0 likes
Seeing the content of composit-walls in plane-view
As the subject says, how do I get to see that in plane view? I used Archicad 15 for a while some time ago, and I remember beeing able to see for instance insulation within the wooden composite wall when beeing in plane view. In 16, however, I haven't...
Edit story levels
Hi, I want to copy the walls and columns from ground floor plan to first floor plan in version 14.unfortunately, when I go to design menu , the EDIT STORY LEVELS is inactive.Any idea how can I copy the walls and columns from one level to another?(ple...
  • 1152 Views
  • 1 replies
  • 0 likes
I cant see doors and windows
This Story(underground) on the picture needs to have doors and windows but floor keeps getting on its way?I dont get it ?is it because this floor is underground or something else?Is there a way to fix it?Thanks for helping noob
  • 2337 Views
  • 2 replies
  • 0 likes
renovation tool - two openings for one window? V 16
In renovation tool, am adding new skin (4" insulation with sheathing) to existing 2x4 frame. Insulation skin is drawn as "new" construction against edge of "existing" wall. When I place a window in the new skin layer however, I also need to cut an op...
  • 1439 Views
  • 1 replies
  • 0 likes
archicad 15 problem in 3d window
I have a problem in my archicad, i was working in a project but the 3d window froze and i can't move the view and it looks as it is all zoomed in. the rest works normally but the 3d window doesnt, how can i fix that ?[/img]
  • 791 Views
  • 0 replies
  • 0 likes
Customize Windows Marker
How can i make the window marker look like this: (see attachment). I have to make it look like this because this is the format they use at the studio im working. Thanks![/img] its width X Height over Sill
  • 847 Views
  • 0 replies
  • 0 likes
