Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 9150 Views
  • 127 replies
  • 18 likes
Door 3D view simplified, not MVO
Hello, I was working in plan copying a door to an exterior wall using the eye dropper tool. When I looked at the door in 3D it no longer has any detail and assumes the surface of the wall, only an outline of the opening is visible. In plan it looks c...
Window Issues
Hello Graphisoft Community, I'm discovering more and more "errors" in the programming of Archicad windows... - In the austrian Version for example, the window casing is in the floorplan and in the section not visible. - The Insulation reveal is unfot...
mbrf by Contributor
  • 640 Views
  • 4 replies
  • 0 likes
Resolved! Object is not selectable after "use fills" are turned off
Hi, Object(windows, door) becomes not selectable after "USE FILLS" are disabled from "Floor plan and Section" from settings. Is that ok behavior? I don't fint a place where to click to select them after disabling fills, even thick lines not going to ...
kosta by Booster
  • 599 Views
  • 6 replies
  • 0 likes
Resolved! Trying to Make Railing Horizontal
I'm trying to make horizontal railings for a deck however they keep making themselves sloped at the ends. I can't seem to find the setting to get the railings to not do that. Can someone suggest a solution? I'm new to Archicad but so far the good has...
Screen Shot 2022-02-25 at 9.38.49 PM.jpg Screen Shot 2022-02-25 at 9.39.18 PM.jpg
Doors have disappeared Archicad 23
Hi, My doors disappeared, all of them. I still have my windows. They aren't visible in the 3D view either. I think it may have happened after I changed the storey level. I changed it back to level 0 however they are still gone??I use Macbook Pro. Any...
ngoldie by Participant
  • 545 Views
  • 3 replies
  • 0 likes
Chapters in energy evaluation report
Hey... So im using student version of Archicad... And i did few energy simulation. Where i found out that my report was missing few chapters.. Compared to other reports on web... When i checked "report chapters " there were only 4 or 5 topics. Where ...
CHARAN by Newcomer
  • 303 Views
  • 1 replies
  • 0 likes
Resolved! Renovation filters behave strange
Hi.All is good except new elements are displaying walls while I have only doors to be demolished, I don't want that opening to be filled with wall after door is taken out of wall, it should left the passage in idea.First is existing plan and is ok Se...
kosta by Booster
  • 1022 Views
  • 10 replies
  • 0 likes
Resolved! Can't find socket and switch symbols I need in AC library
Hi ! I Cant find sockets in library, there are some but looks like they all are unfinished for meI need symbols like those one on picture.Also I can't customize the ones AC have, What I'm missing? Can I somehow customize existing ones under my needs ...
kosta by Booster
  • 612 Views
  • 4 replies
  • 0 likes
