Meshes from ArchiCAD 14 not showing in 15
I recently upgraded to AC15, but on all my files from AC14, none of the topography meshes show up in 3D, only on 2D...any ideas??
A colleague has a problem across multiple projects where her trace referenced plans are only showing up the top left quarter under her working storey. It is as if there is a large masking fill across the rest. When you pan the view the trace referenc...
It appears that the windows (or at least this one) are not drawing correctly. Setting for this window is 7'-4", and the window hole is correct. However, it leaves a four inch gap at the bottom. If I turn on the sill, stool and apron, those elements f...
As a quick fix solution for someone I tried using James Murray's Shape label JM9-12 (in the depository), for an AC12 project as a door and window marker. Unfortunately it doesn't read the d/w ID's. I tried it two ways, 1. -select the doors and window...
Hi, I am working on 15 and I create a custom panel door. I choose the right material fro the glass and for the style and rail. when i generate any 3D or Elevatins I cann'ot see the trasparency. Please any suggestion and help. Thanks
I have an issue with cloned folders and interior elevation markers. I've made the markers reference to drawings placed on the layout, but for some reason, possibly a bug, the interior elevation names are not the same as those shown in the clone - see...
I have an old concrete eve on the outside wall that i wanted to recreate. designed it up using profile editor and saved it as a beam. Brought the beam around to where i wanted the eve. It works almost perfect. only 2 little problems. actually 3? 1. i...
i have an internal wall inside my house. about 3 meters a´way there is a complex profile beam (gutter) the gutter does not go any where near this internal wall. But what ever i do, there is the profile cut of my gutter cutting straight through the wa...
I am trying to insert parameters in a paragraph in my 2D GDL script. Whenever I change from normal text to a parameter, all the font settings change. See below bold the field that I have changed to a parameter (therefore removing the quotation marks ...
I am on AC15, working with the new roof tool and inadvertently, I must have done something that display the roofs in "wireline" mode. The rest of the model is correct, but the roof is transparent. Please help. Thanks
User | Count |
27 | |
8 | |
7 | |
7 | |
6 |
