Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 9150 Views
  • 127 replies
  • 18 likes
How to create custom door layouts ?
Hi! How to create custom door ? like that one below: As you can see it has a door at right side and 2 frame divisions on the left side.Can I easily edit or create any custom door layout? Maybe somehow rearrange existing elements and not create those ...
kosta by Booster
  • 599 Views
  • 6 replies
  • 0 likes
Resolved! General Pens
Hi,I was 3D modelling and I needed to change the lineweight of a wall where I have a sliding door(blue line in the pic). The internal face of the wall has the lineweight assigned to the General Cut pen and I was not able to change that from the wall ...
Resolved! How to remove last dimension point ?
Hi , How to step back while setting dim points ? Like if I drawing a chained line I can press Backspace button and it will remove last set point.
kosta by Booster
  • 421 Views
  • 2 replies
  • 0 likes
Resolved! Param-o missing fill from existing (referenced) objects.
hi all, 1. is an existing object,2. in Param-o it is imported (like the two others) I can change the fill to whatever I want in the original objects - Param-o shows always just lines, but nor fills.How can I get my fills back?Please, let there be a s...
Resolved! Stairs and railings
HI. Whenever I add an 'Associative' railing to a staircase the railing reuses to be vertical. On the horizontal landing the railing and balustrades are perfectly vertical, but, on the sloping stairs the rail balustrades lean at an angle ('skewed') – ...
Dali_ by Contributor
  • 679 Views
  • 3 replies
  • 0 likes
Main file size Bloated after Hotlinking a File
Hi all, My main file size increases tremendously from 14mb to 200mb whenever i hotlink this particular file. This does not happen when i hotlink any other files to my main file. PS: Main file is an empty file that is used to hotlink other files into ...
astonyap by Participant
  • 577 Views
  • 2 replies
  • 0 likes
