Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 9388 Views
  • 127 replies
  • 19 likes
Site Plan help:DWG import, scale contol and WCS coordinating
Hi, I have a UK Ordnance Survey map, in 2D DWG format, which is to be the basis of my site plan & project. I was planning to merge it into a lower story and use it as an underlay to draw up a 2d site plan initially and eventually graduating to a 3d t...
Aquavit by Participant
  • 8575 Views
  • 5 replies
  • 0 likes
todays blond question ? finding a straight line ?
ok very stupid question buts its annoying me. about 1 week agao, when i started to draw a line, i picked a point and then i would move the second point a little in a straight direction and archicad would show me some lovly orange help lines and i cou...
Anonymous by Not applicable
  • 2111 Views
  • 3 replies
  • 0 likes
Dorr Markers rotated 90 degrees
When I place an associative lable for my doors, the number is rotated 90 degrees, and I can't figure out how to correct this. Can anybody help me?
GSM file got problem in archicad 15
hi, i am archicad 15 user. i got a gsm file in my drawing, the gms file can show it on my archicad-14. but after i updated my archicad to version 15, it can't read my gsm file & also can't show the object (gsm file) on my drawing. it keep said " inte...
  • 7223 Views
  • 5 replies
  • 0 likes
Shells using composite structures
Greetings - It was my understanding that the AC15 Shell tool could use composite structures for the cut fill of the shell. When attempting to apply a composite structure, no composite structures appear in the cut fill list under 'Structure.' Solid, v...
Zones around door
Hi all. If I have door with reveal on zero elevation from the wall base, then zone is nicely set also inside the wall, but if I raise the door from the ground, zone ignores reveal. How do I avoid that with raised door?
  • 1019 Views
  • 0 replies
  • 0 likes
Skate parks
I am looking for any skate park GDL's that any body has made. I teach Architecture to my high school class and the boys are designing a park for a new estate and would like the park to include a skate park or half pipe or bowl. I have tried making my...
  • 10982 Views
  • 8 replies
  • 0 likes
Doors and Windows List for Modules
Hi there, I hope this is the right place to post this for help. I have a large project that requires using modules. eg, module type 1 is placed into project file 50 time and module type 2 is also placed into the project file 50 time. 100 units in tot...
  • 12098 Views
  • 2 replies
  • 0 likes
  • 3954 Views
  • 3 replies
  • 0 likes
