Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 5113 Views
  • 121 replies
  • 13 likes
Global Variable incorrect?
Hi folks, bit of a random one here. I've adapted Daniel Lindahl's position marker object to create an object with the following code in 2D: sz=sz/1000 GLOB_SCALE=A_ MUL2 A_,A_ pX = (X~ + 0.0) pY = (Y~ + 0.0) PARAMETERS pX=pX, pY=pY IF coord=ac1 THEN ...
Framing tool
Have shown my projects framed in 3d for years, but can't find the framing tool any more. Does it still exist, did I forget, know it was difficult to use, but figured it out and need it now. Anybody know what I am referring to?
Anonymous by Not applicable
  • 1330 Views
  • 1 replies
  • 0 likes
man sitting 2 14
using this new object, with the 3D view marquee'd it doesn't show in the window but if i show all or show only selection it does. anyone had this problem? is it the object or a funny setting somewhere, the old standing up people work fine. cheers
  • 1988 Views
  • 2 replies
  • 0 likes
Start error :(
I installed and setup Archicad13 Education version. But I can't open it. It gives an error every opening. I have Quicktime 7.6.8. and I use Windows 7. What can I do? Problem: QuickTime is either outdated, not properly installed or missing. ArchiCAD 6...
  • 4657 Views
  • 0 replies
  • 0 likes
Custom Object Location
I have numerous custom objects, but I made the mistake of saving them in a "Custom Objects" folder that I made in my AC13 Library. It has been brought to my attention that they should have gone into the embedded library instead. I am going to switch ...
  • 2964 Views
  • 4 replies
  • 0 likes
removing window lines
does any one know how to get rid of the lines on windows and doors in drawings that indicte which way it opens? on archicad13 thanks
  • 13814 Views
  • 9 replies
  • 0 likes
Windows in profile wall
Hello, I am trying to put a window in a curtain wall, as you can see in the picture. When I put a window, there is a hole on the other side. How this can be fixed? regards, Petar
  • 1160 Views
  • 1 replies
  • 0 likes
CAD Standards the Rules....
The following rules apply to any CAD package be it 2d only or full BIM (well ok some of em are ArchiCAD specific) 1 Never leave anything on the ArchiCAD or Zero layer. This is punishable by having the fingers on your right hand chopped off in most of...
