Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 5005 Views
  • 121 replies
  • 13 likes
Survey follow-up – Door/Window Detail Level
Dear Community, Many of you took part in our recent survey on “Detail Levels of doors and windows on a single drawing”: https://community.Graphisoft.com/t5/Document-Visualize-forum/Doors-amp-Windows-Detail-Levels-within-a-single-drawing-1-minute/m-p/...
Stone frames in windows,possible?(check image)
It is possible to do in 3d in archicad? I want do the stone frames that round the door and the windows (blue marked) The red circle suggest other question that I think that archicad don't do it in a easy way. Is it possible to do in 3d?
Anonymous by Not applicable
  • 7743 Views
  • 10 replies
  • 0 likes
Creating an object in a 3-dimensional coordinate system
What's the best way to create an object (or a slab, or whatever is the best option...) between the yellow and the blue shapes. The red hexagon is horizontal, and the others are rotated in different angles using the z line. So basically the question i...
  • 4948 Views
  • 7 replies
  • 0 likes
Reset "recent files"
When I start AC14 I get this dialog below. The two projects are exactly the same and there are only one of them on BIM-Server. How do I reset the "recent files" log? This occured after I deleted a file named connections.xml and I did this because I h...
  • 1079 Views
  • 0 replies
  • 0 likes
Label arrows
I have created a relatively simple label and was wondering if there was an easy way to add a leader line and arrow to the part. If is tick 'Label Elements' and use the custom label on an object, the line and arrow is added automatically. Alternativel...
wilson83 by Participant
  • 3091 Views
  • 2 replies
  • 0 likes
