Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 9301 Views
  • 127 replies
  • 18 likes
Masonry Arch Pen - Opening D Rectangular 14 - where is it ?
Please could some kind soul let me know where I can change the pen choice for the masonry arch in the 'Opening D Rectangular 14' door library object? I can find it easily enough in other door objects (as shown in the view of 'D1 Entrance 14' in the f...
PB by Enthusiast
  • 3473 Views
  • 5 replies
  • 0 likes
Skylight 12 oddness
This pln file was migrated from older computer, but still from AC-12, with the same 2 libraries, (AC-12 and my standard office library). It's Skylight Flat Panel-12 right from AC-12 lib. Whether moving or deleting the skylight, the opening remained n...
Anonymous by Not applicable
  • 2804 Views
  • 4 replies
  • 0 likes
Importing mesh into AC 14 or 13
Hello! I have a really big issue... I need to create a very complex mesh, and it would save me a lot of time if I would be able to import it from google earth.. (I already have it imported in sketchup 8 ). As I mentioned in the title, I have AC 13 or...
  • 2485 Views
  • 2 replies
  • 0 likes
Vitra furniture in ArchiCAD
Hello, I would love to use Vitra furniture in my project for school... also Fritz Hansen ones. Are they available for ArchiCAD or in any format that can be converted to ArchiCAD? I have searched in forum and internet and I only arrive to pages that d...
  • 18328 Views
  • 10 replies
  • 0 likes
Drawing irregular walls
Hello I need help drawing complex walls in ArchiCad. I can't find any tool that enables drawing irregular walls like the one on the picture. Any help would be appriciated
  • 1442 Views
  • 1 replies
  • 0 likes
Scale sensitive not working in section
Hello, I'm noticing something strange. When I place a door or window in ArchiCAD, and I activate the option "scale sensitive", works great in plan. There is a difference between 1:300 and 1:20. That's fine. The problem is when I look at a section. Th...
  • 4425 Views
  • 7 replies
  • 0 likes
Zone Stamp - wrong measured area
Greetings all, using the Masterzone (formerly known as Superzone-2), the Measured Area calculated value is incorrect. In the attached screenshot you can see the Measured Net Area is 221 SF, however the Measured Area returns an incorrect value of 6,00...
font drivers and or library
I am loading a file created in V.11 in V.13 I have loaded all the libaries from V. 11 and all my objects appear correctly except all text. The text shows up symbols. I was using country blueprint as a text font.
  • 2269 Views
  • 3 replies
  • 0 likes
Hotfix for ArchiCAD 13 and 14
Dear ArchiCAD-Talkers, We have released Hotfixes today for both ArchiCAD 13 and 14. They are currently available for INT, USA and AUS language versions through the Help menu/Check for Updates... command. Other language versions will follow soon. The ...
