Truss maker problem
When i try to create a truss from lines, i get this message: Truss maker can`t work: segment overlap What seems to be the problem?
I am trying to achieve the light-coloured stepped stone detail shown on the photo below, how can I achieve something like this in Archicad? My initial thoughts are the a small and thin walls using the wall tool, which when I've created a couple would...
I am trying to replicate a profiled cast iron column. So far, the best method I have come up with is to use the beam tool to create a slim beam and then apply a complex profile. Is there a better way ? These are what I am trying to achieve:- http://i...
hi, Please see attached. I'm wondering: can we set start position of the vectorial hatching for the wall? I'm using wall's material, NOT a seperate fill layer. (With Fill, I know how to set the start position) Please advise Many thanks
I am biulding now a house and everything is almost finished ,but i can't find lamps in Archicad. I read in one guide that there is a Archicad lamp world but i can't find it free, so my question is: Where can i find lamps in Archicad if they are in it...
Hi everybody, I was working on a curtain wall in the 3D editing mode. All the sudden AC12 froze and I could not do anything, could not finish editing the elements I was working on, and I could not even move around in the 3D view or exit the editing m...
I hope it's corrected with Archicad 13 (I'm waiting it ), but I find very annoying that Archicad 12 doesn't reshape window size the right way when I use partial structure views. I attach some screenshot to explain better the problem. And... I wish I ...
Hi I have problem with my object. My friend had made me script for some object but it look it is not finished and i have no contact with him. I need help with 2d script and parameter script. Now i have one txt file in witch i can put dimension for au...
Anyone know if there is a way to turn of the new "feature" that shows the anchor point of text blocks and leaders as a big bold "+" without turning off the handles? Or a way to change them to be less annoying (ie less bold, diff color) I can't find a...
Is there a way to label Archicad12 standard Skylight object (Skylight top hung) and put them into a schedule. I was thinking there should be an option to add a window marker and a parameters for listing section too for a schedule. Is this the typical...
User | Count |
27 | |
8 | |
7 | |
7 | |
6 |
