Lost 3D Model
Hello, I have lost my 3D model! I think I zoomed too much and I can't find it now. Is there a function like the AutoCAD zoom extents where it zooms to fit the window? Thank you! Sue
Hi All I didn't know which forum to put it, but this is kind of an "IT manager" problem, maybe this forum is OK. Since the last patch update 2675 (I'm stating this only because I've never had a problem with this before) I am unable to correctly impor...
How can I undo a SOE where I selected extrude upwards instead of extude downward by mistake? The undo button doesn't work and the SOE operator tool allows only the cancelling of operators not targets. In this particular case I can select the operator...
Hi, I'm having some difficulties seeing a 3D picture of a series of portals I am constructing. At some point the portals vanish into thin air in the 3D window, while they are still there in the floor plans. Is it something in the settings I need to a...
It is possible to make an object that is visible on more than one story and shows different 2d-symbols on each story. If yes, how?
I just need some opinions. Is it better when working with exterior walls to have one wall continuing through all floors or have seperate walls on different slabs.
Whenever I use the roof wizard it always ends up putting the rafters on top of the roof. Is there a setting that controls this that I'm missing?
Guys i have a little problem. When i upgraded the archicad with the 2675 hotfix the plumbing fixtures dissapeared. what remained were just two kind of showers a shower spray and a tap... What could be the problem. I'm with the latest archicad 12 libr...
any good locations for good play ground equipment objects(not wood)
How many Model View Options do I really need? All of the graphics in the dialog boxes show plan graphics, are these options for plan control only or should I be creating a view option for elevations and sections?
User | Count |
27 | |
14 | |
6 | |
6 | |
5 |
