Marquee tool-color cut parts show up
HI all- isn't there a way I can specify what color the stuff cut by my marquee will be?
I am trying to do the slab intersecting with a mesh to create pavement that follows the terrain trick, and for some reason nothing happens. This is something I have done many times, and SEOs work else where in the project so I am totally stumped. Any...
Hi, Odd request, does anyone have or know where i can find a good Library Part of a pram or buggy? I need one for space planning on one of our projects . . . I have got the one that is on the Archibase site, and it looks a bit 60's Thanks,
Hi, I create a new stair successfully. But the function in the Stair Setting Dialogue: [ 2D Symbol, Arrowheads,Batten and Flight ] does not exist. I can't modify the arrowhead, 2d symbol...etc.... Anybody know the reason and how to overcome this ? Pl...
Hi all, I know how to change background color from white (as default) to black (in Grid Options). In that, I use a white pen color. But When I print it out, the white pen color is not automatically converted to black, not like in AutoCAD. Does any on...
as it can select the whole building by using the thick marquee, and the thin marquee can also select one floor. and I select only a little part by a marquee to show in 3D??? for example, a window with some little part of wall?
Hi all, I wonder how to create this wall? Using complex profile or a simple wall tool or something else? Please advise. Many thanks p.s. This wall is the the side wall of a disable ramp.
I have created a library part to represent a back woods outdoor toilet typically found in America. I am using the object in a presentation on "adaptive re-use" where I take this primitive outdoor toilet and transform it into a modern living room furn...
Hi, Is there away to asssign 2 different material on one side of a Slab/Wall ? Please advise. Many thanks
hi, i just read a little bit of the GDL technology and Iam searching for an ideo to convert 2d fillings in AC to simple 3d forms. I need that for a site plan with many houses (blocks with some atriums). I have these plans in simple 2d fillings (dxf/d...
User | Count |
28 | |
17 | |
5 | |
5 | |
5 |
