Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 9160 Views
  • 127 replies
  • 18 likes
Flat roof and curtain wall how to?
Dear all, I am creating building in ArchiCAD12. ROOF: my questions are the following: - how can I design a roof which is flat? It has to have a 1% decline but only in some parts of the composite structure (thermal insulation is inside, then concrete ...
Anonymous by Not applicable
  • 3304 Views
  • 1 replies
  • 0 likes
Roof curvature
Hi there guys. Just wanted to know if someone can give me a way to either use the roof tool or mesh tool and get it to curve up and down, just like the attached file. I'm just learning with the new ways do to things in ArchiCAD, and I will appreciate...
  • 2089 Views
  • 4 replies
  • 0 likes
Walking figures
Hi All A friend of mine, Thomas Roth has spent a lot of time building ArchiPuppet, a walking & moving figure for ArchiCAD 9 to 12. You can see a video & download a free full working demo of it from here: objectstop.com/?p=369 He's also set up a coupo...
  • 1226 Views
  • 0 replies
  • 0 likes
Corner windows
I can't find the corner window tool. Is this an add on? Or is it somewhere hidden in another tooldialog?
  • 1619 Views
  • 2 replies
  • 0 likes
Rotating a Custom Title
Hi I create a new title for my drawing,but I can not rotate like Archicad title, there is a way you can do that? Thanks
  • 1552 Views
  • 2 replies
  • 0 likes
Constructing Curved & Inclined Wall & Associating Window
Hi, I am learning ArchiCAD at the moment and working on a project. I am trying to curve & incline a wall around a fairly tight curve that has a larger footprint on the ground compared to the curve that meets the roof. I haven't managed to do this and...
  • 12716 Views
  • 12 replies
  • 0 likes
change the height of a curtain wall
HOW CAN SOMEONE CHANGE THE HEIGHT OF THE CURTAIN WALL AFTER THE CONSTRUCTION OF IT???? IT SEEMS THERE IS NO OPTION IN RIGHT CLICK MENU TO CHANGE DYNAMICALLY (AS YOU DO IN A WALL FOR INSTANCE) THE HEIGHT (THE TOTAL HEIGHT) OF A CURTAIN WALL. IS IT POS...
  • 5863 Views
  • 3 replies
  • 0 likes
Line tool Default layer changing after using fill tool
Small but annoying problem, long explanation. Has anyone else experienced the following? I draw a line on a visible layer, then select the Fill tool to draw a fill. If I go back to the Line tool the default layer has changed to something else. In thi...
  • 2768 Views
  • 3 replies
  • 0 likes
