Design forum
Forum Posts
Missing lybrary objects from German version template
Hello everyone, I have the following problem. I am based in Bulgaria and use Archicad 22 in English. I am working with architects from Germany. They have sent me a template file created with a German version of Archicad 22, however when I opened it, ...
Anonymous by Not applicable
  • 457 Views
  • 2 replies
  • 0 likes
Wall contour from current floor on floor above
Hello, I am trying to achieve the projected wall from ground floor story to the roof story. In picture one, is the effect i achieved using show wall on al relevant storys but i can't see through it, it cuts the roof In picture two is the effect i wan...
  • 614 Views
  • 5 replies
  • 0 likes
Slow window refresh in A21
Hello all, on my Win10pro with Ryzen 8 core with 64Gb Ram and 1060 with 6Gb video i got very slow refresh when switch between 2 views. Its a TEAMWORK project. No problem in ArchiCAD22 or Archicad20, only in v21. Refresh can be about 30 sec. On mac no...
  • 620 Views
  • 0 replies
  • 0 likes
Spiral with newel
Please how can I make a spiral with diameter of less than 1 meter such as 700mm? I can do it only around 1 meter or bigger! Thanks
Eman by Participant
  • 671 Views
  • 5 replies
  • 0 likes
Curtain Wall Panel Element ID
For enlarged elevations, we tag each curtain wall panel with type. I'm using the new panel classes in Archicad 22 to create all of my panel types, set the element ID in the panel types to be consistent with our legend, then I label them on the elevat...
  • 499 Views
  • 2 replies
  • 0 likes
Mesh tool not working like the video
I have created a mesh rectangle. Selected it. Then use the magic wand over a 2D cad drawing on a worksheet which is showing contours as a trace and reference. I had the spacebar and click, but the mesh deselects. There was no Magic Wand icon on the c...
Cropped Composite Dropdown
Hello, I'm not sure if this is a bug or not but my composite drop-down menu is cropped so that I can only see part of the composite name (see attached picture). To be able to see the entire composite name I have to open the composite pallet and it li...
Didn't find the answer? Start a new discussion
Labels
