Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 9156 Views
  • 127 replies
  • 18 likes
Dimentions
I have dimensions being delated by ArciCad. I'm using a complexed profile wall. Had the foundation fully dimensioned, went to the floor plan, came back and most of the dimensions associated with the walls where gone. BUT not all, the garage foundatio...
Anonymous by Not applicable
  • 3946 Views
  • 6 replies
  • 0 likes
Cant change Section Reference ID
I cant change the Reference ID in my section selection settings. What is the setting that will allow me to change my section ref id? I searched but couldnt find the answer. Thanks!
  • 1484 Views
  • 3 replies
  • 0 likes
Interactive 3D cutting planes
Hola, Is this possible in AC11? The cutting plane tool is nice, but not as interactive as it would be desired. I would like to modify cutting plane locations directly in the 3D window... or even in the dialog box that appears and see the changes as I...
  • 2624 Views
  • 4 replies
  • 0 likes
Archicad crashes when I save my work.
Hi yall Everytime I go to save my work as of late (one particular file only) archicad crashes, the bug reporter appears much to my dismay. So basically I have to wait until the file autosaves, otherwise I have no other way of saving. I have tried dup...
  • 827 Views
  • 0 replies
  • 0 likes
Shortcut for Display Order?
Is there a shortcut for alternating between the Display Order (bringing something forward or sending backward) of a selected element?
  • 4171 Views
  • 3 replies
  • 0 likes
Object w/ wrong dimensions
Anyone ever have problems with the Archicad object "plotter 11" where one of the dimensions is always 76% smaller than the inputted dimension? Image is hard to read, object should be 6'X6'. Know of any other objects with similar problems?
  • 2552 Views
  • 3 replies
  • 0 likes
swing side request??
Hi All, Could anyone tell me how to request the swing side of a door? I'd like to place a custom marker always next to the door leaf no matter which side the door swings. Thanks! Adam
FIGURE TOOL QUESTION
I have a problem with an image in jpg format inserted as backgound to a drawing (using figure tool) compiled first in AC9 and then converted to AC11. The image is no longer visible, even though the outline still lives on that layer, I just cannot vie...
Fritz T by Participant
  • 1096 Views
  • 1 replies
  • 0 likes
Library problems
Hi, I get massive error messages every time i add, or edit a door, i have found some minor threads concerning similar problems but not quite the same. Im running archicad 11 on a macbook pro, and the following errors are what appear. Fill not found a...
  • 11025 Views
  • 10 replies
  • 0 likes
