Design forum
Forum Posts
edit custom window
Hello! Is there a way to edit a custom made window or door? I know I can edit its parameters, but what if it has some unusual shape and I need to change a part of its form? Thank you!
Anonymous by Not applicable
  • 169 Views
  • 1 replies
  • 0 likes
Update library parts advanced
Hello everyone, Has the "Update library parts advanced" Library Developed function discontinued in AC 21/22 versions? Is there another way to hide scripts?
2D Symbol Insertion Point using GDL scripting
Hi everyone, I'm fairly new to GDL and scripting in Archicad all together but I'm in urgent need of creating this specific type of door for my project. This door began as a Revit door which I was able to import using the Import RFA as GDL plugin. I w...
  • 1238 Views
  • 19 replies
  • 0 likes
PRISM_ STATUS CODES: EDGE NOT SHOWING ON CYLINDER-LIKE PRISM
Hello, I am creating a simple spout object and I have set the status code to make the bottom edge visible and side surface present. This works great in 3D, however in 2D the outlines of the Prism_ are not showing. I have had a look at Barry Kelly's c...
  • 249 Views
  • 2 replies
  • 0 likes
Importing Sketchup into Archicad
Every time I import a Sketchup object into Archicad (usually a piece of furniture of a fixture of some sort), it imports at a 3.19° skew. Does anyone know why this happens and, more importantly, how to fix it?
  • 281 Views
  • 1 replies
  • 0 likes
Trim-to-Roof a Wall of Hotlink Mod?
Hi all, I have hotlink modules in the master file. I want to trim-to-roof certain walls of Modules in the master file but I can't. Am I missing something or is it impossible? Thank you
  • 300 Views
  • 4 replies
  • 0 likes
Resolved! Can't Place Library Objects from IFC file into New Project
Hello, I am fairly new to Archicad but have followed along with online tutorials to learn basics. I've currently been tasked to recreate a model (created originally in Revit) within Archicad. I've gotten the Revit file converted to an IFC file (throu...
  • 474 Views
  • 3 replies
  • 0 likes
Resolved! Is there in Archicad something that works as Block in Autocad?
I am desperately trying to figure out how to make something like Block in Autocad, that I can place, edit and save, but in Archicad. I have tried with Objects, Module, but I can't find edit mode for the GSM objects (only for Attributes) and the modul...
  • 405 Views
  • 3 replies
  • 0 likes
Didn't find the answer? Start a new discussion
Labels
