Design forum
Forum Posts
GDL to GSM
Is it possible to import a .gdl file into archicad as an object, or does it first need to be converted to a .gsm file to match all the other library parts? And if so, what's the best way of doing this? Thanks in advance for any replies Joel
Anonymous by Not applicable
  • 1368 Views
  • 2 replies
  • 0 likes
ArchiCAD 11 Hotfix (build 1114)
Dear ArchiCAD-Talkers, We have released Hotfix 1114 for ArchiCAD 11 INT and USA version. It applies to Commercial, Trial and Educational licenses. Before installing the Hotfix, please take a moment to read the Release Notes! To download the Hotfix, p...
AndorSzoke by Graphisoft Alumni
  • 21328 Views
  • 25 replies
  • 0 likes
Favourites palette
Hi All, I think the favourites palette is a great idea, however I'm finding it a bit temperamental when it comes to saving favourites for slab's. I want to save a list of slab types: ceilings @ 28c, 31c, 32, floor slab @ 0c (100mm thick) and so on .....
  • 807 Views
  • 0 replies
  • 0 likes
3D CUTTING PLANE WINDOW
I KNOW THIS IS A STUPID CUESTION, BUT HOW I CAN ZOOM IN OR ZOOM OUT THE PROJECT IN THE 3D CUTTING PLANE WINDOW
  • 8027 Views
  • 10 replies
  • 0 likes
chairs off set in 3-d
i am using a chair from the archicad 11 library. I set in in plan, and in 3-d it is offset from its orginial location... i've looked in the object settings.. but can't figure it out... help please!
  • 3168 Views
  • 6 replies
  • 0 likes
Conflict between versions.
Can anyone help? I am working on a project for school. The computer I use at school is archicad 10. I been adding furniture into the plan. I have archicad 11 at home. When I open the plan at home there is no furniture. There is nothing in my furnitur...
  • 4516 Views
  • 3 replies
  • 0 likes
Publishing AC-9 Files As DWG
i have a plotmaker file with 3 Pages A001,A002,A003 i publish these pages as a DWG file,so i can send them of to the engineers on this particular job, who usees AUTO CAD. For Some Reason when they download the DWG's i sent them none of the text show ...
  • 1284 Views
  • 2 replies
  • 0 likes
preview of gdl still missing
hi there! I've been using some gdl objects that I collected from the web and imported them into my projects using archicad10. now I switched to archicad11 and now when I'm clickinh through my own library with the collected gsm files... I can only see...
  • 6277 Views
  • 13 replies
  • 0 likes
Shape Tag JM9 Fill?
Regarding Shape Tag JM9, is there a way to give this tag a fill? For example, on a floor finish plan, you wouldn't want a ceramic tile floor fill showing through the shape tag.
  • 1489 Views
  • 2 replies
  • 0 likes
3ds conversion problem
I am having a bit of trouble converting most objects from .3ds to .gdl. I have just purchased AC11 and have downloaded the 3ds coversion goodie, but I can't seem to get the objects to convert. Does anyone know what the problem might be? Justin
  • 2886 Views
  • 5 replies
  • 0 likes
Didn't find the answer? Start a new discussion
Labels
