Design forum
Forum Posts
wall priority help
not sure i understand exactly how wall priorities work..what exactly would be the correct priorities for this intersection to be accurate?
Anonymous by Not applicable
  • 53726 Views
  • 41 replies
  • 0 likes
Weird Box/window in 3D window
Has anyone run across this odd box shape while working in the 3D window in AC10 OpenGL mode? It some times remembers the view that was in the area of the shape when you move around your model. See attached image.
  • 918 Views
  • 0 replies
  • 0 likes
Stucco Pop-outs & parapet walls
What is the best way to create these elements? For stucco pop-outs around a window I was thinking the beam tool but that logic says why not the column tool so is there a reason why one is better then the other? Or maybe a better way altogether? As fo...
  • 3176 Views
  • 2 replies
  • 0 likes
Favorites DIMENSIONS
Does any one have a system for recording the commonly used dimensions or notes. Like the favorites system. There is so much math to use AC10 well that I often find myself spending lots of time just to find out what was a dimension or..?...that I used...
  • 1119 Views
  • 1 replies
  • 0 likes
Curtain Wall in Section
I have a vertically butt glazed curtain wall. I have not been able to get the Horizontial Mullions to show in section. All I see is the solid area where the mullion should be if it passed thru or intersected the glass. I have tried all of the control...
  • 1396 Views
  • 2 replies
  • 0 likes
  • 1505 Views
  • 4 replies
  • 0 likes
Cut Fills not showing
OK this sounds like the most basic of questions but I cannot seem to get my sections to show a fill. I am just experimenting with how I wish for them to look on the construction docs and applying a cut fill to any element is not working, the fill lin...
  • 4439 Views
  • 8 replies
  • 0 likes
Complex profile, edge problems.
I cannot figure out what is going on with this profile. I have built others and have not had the problem when my curves change into straight lines. Maybe somebody has a idea about what happened. In the complex profile tool everything looks fine but w...
Origin moved in paperspace in dwg-export!
Hello I´m trying to export a layout from AC10 to autocad. I´m using the paperspace with full drawing content-option. The strange thing is that the dwg model file has the same origin as the archicad file and the Paper Space file doesnt. Im trying to d...
  • 1203 Views
  • 1 replies
  • 0 likes
Didn't find the answer? Start a new discussion
Labels
