Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 5305 Views
  • 121 replies
  • 13 likes
window issues
I am getting loads of "polygon is degenerated" error messages when I try to view my model in section or elevation...I have been tweaking the parameters to try to get the windows to look like I want, so I must have tweaked Something, but I can't figur...
Anonymous by Not applicable
  • 1054 Views
  • 1 replies
  • 0 likes
3D to 2D
Another beginner question. What is the best way to convert a 3D elevation (for example) into a 2D drawing and if possible keep the 3D version. So near the end of a project detail can be added, lines can be trimmed, etc. Thanks.
  • 3654 Views
  • 3 replies
  • 0 likes
Door Centerline Removal
I am trying to remove the centerline that is associated with my door dimensions but it doesnt seem to want to go anywhere. Any suggestions on how I might do this? Should be simple, if it is possible at all... I just cant figure it out. Thanks Mike Ar...
  • 1380 Views
  • 1 replies
  • 0 likes
lamps in slabs and walls
Hi everybody, I'm wondering if there's a way to script gdl lamps to cut holes when inserted in slabs and walls.
  • 2061 Views
  • 4 replies
  • 0 likes
About The Architects' Journal (especially for the Brits)
In the issue of 15.09.05 of the ever-increasingly scrwd up The Architects' Journal, section 'Technical & Practice', a Joe Croser gives advice on BIM products disregarding ArchiCAD with the following words: 'As a 2D drafting tool ArchiCAD is much easi...
Ignacio by Expert
  • 12981 Views
  • 15 replies
  • 0 likes
Problem: "cannot find pict file" ????
hi everybody... i'm experiencing this strange problem... i'm running AC9 with OSX 10.3.9 every time i open a specific document, i get a series of warnings, that say: cannot find pict file "xyz" called at line "xyz" of the file master_gdl. This also h...
"Please help me find a specific library part"
I am currently doing a project on a type 1 Volkswagen Beetle. I would really appreciate it if anyone could suggest where to find it as an add-on library part for the Archi-CAD programme. All i can seem to find is the New type VW Beetle. Thank you
  • 3692 Views
  • 2 replies
  • 0 likes
Can't create a "spanish french door" panel
I am trying to create a "spanish" style grid pattern on my exterior french door in Special Edition Lib 9. What I am trying to accomplish is getting 3 horzontal grids in the glass (these I get ) and NO vertical mullions (enter "0" in the field and thi...
  • 2483 Views
  • 5 replies
  • 0 likes
Doing a fence/wire facade...is it possible
I am working on a project for my graduate studio that has a metal fencing with strips of metal woven thrown it at certain parts as part of the facade. I want to model it in ArchiCAD but I'm not sure how to. I am somewhat new to ArchiCAD so if anyone ...
  • 8894 Views
  • 3 replies
  • 0 likes
teamwork saving .plp file
Is the only way to save the .plp teamwork file by signing out? I am used to saving the .pln file every once in a while because I'm paranoid about losing information. I'd like to do the same thing with the .plp file. It makes sense that you would not ...
