Design forum
Forum Posts
Mac Stickies when writing GDL
You can now (err, probably since OS X) paste a picture into a Stickies note, find&replace text, keep URLs active. And of course, this being OS X, bring a single note to the front. You can make individual notes translucent, and/or make them stick to t...
Ignacio by Expert
  • 3213 Views
  • 0 replies
  • 0 likes
Fills show through doors
Hello - I have tried many things to have the door show on top of the fill, but always the fill shows through. Any thoughts on how to have the door be on top will be greatly appreciated. Best regards - Chris
Anonymous by Not applicable
  • 2817 Views
  • 5 replies
  • 0 likes
LOCK Not Locking!
I have several LOCK functions in my Master Script that are meant to lock parameters depending on other values. I have at least 3 of them that won't lock the parameter. I've checked it from every angle -- spelling, punctuation, syntax, order of evalua...
  • 8368 Views
  • 16 replies
  • 0 likes
Scaling objects
Isn't there a way to scale an object to each stories scale? The problem is that the object was drawn on 1:1 and then saved as a object, but once it is placed on a 1/4" = 1'-0" then of course the text is right but the drawing is still 1:1. How can I c...
Red by Enthusiast
  • 7742 Views
  • 3 replies
  • 0 likes
Proud Coarse Window Object
Hi All, I'd like to create a window object that sticks to a wall but is actually a proud coarse of brickwork so it sticks out like a square sill. It needs however to run the entire length of the wall, (a bit like reveal maker that I've seen advertise...
Wokka by Newcomer
  • 4812 Views
  • 8 replies
  • 0 likes
Graphical editing inside labels?
Before I chase this too far: Do the diamond "stretchy" hotspots work inside the Label Tool objects? I'm trying to make a label that can have parts of it altered graphically, and the Pet Pallette does not seem to show the traditional "stretchy" option...
TomWaltz by Newcomer
  • 4539 Views
  • 4 replies
  • 0 likes
How to connect a wall to a rotated-column
Howdy fellas, Okay, Here's my next problem...connecting stud partition wall to a C section Column that does not sit 90 degrees to the wall. Take a look at the piccy please. Thanks
  • 1240 Views
  • 1 replies
  • 0 likes
Changing Dimension Ticks
Hello - I have looked in the manual and searched the forum and cannot find an answer to my question. I have also looked through the GDL library. Can I change the width of the tick on the dimension line? I would like to make the ticks considerably thi...
  • 1455 Views
  • 2 replies
  • 0 likes
level dimensions
Hi, Can I somehow get level off bottom surface of the roof with level dimension? Cris
  • 1004 Views
  • 0 replies
  • 0 likes
Cover fill in Plot Maker
Does anyone know about why the cover fill does not appear on the sheet printed, but shown on the plot Maker screen EY
  • 1092 Views
  • 1 replies
  • 0 likes
Didn't find the answer? Start a new discussion
Labels
