Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 9393 Views
  • 127 replies
  • 19 likes
MASS command
Hello, I am working with the MASS command and the manual says the "s" (status of edges) is "similar to the Prism_ statement". Similar but not identical in my experience. I have found that if you use the status value of -1 (an illegal value for the PR...
Anonymous by Not applicable
  • 3400 Views
  • 2 replies
  • 0 likes
Building Rotation (In Plan), & Combining Drawing Files
Couple of questions here... First, how do I rotate (in plan) all stories of my project at the same time? Im guessing there must be a command to select all stories, I just dont know what it is. Secondly, how can I bring a building from one file and pl...
  • 1935 Views
  • 4 replies
  • 0 likes
Module - Sections and Autorebuild.
I am creating a project with many small houses, so i decided to create each one in a seperate module. I created the plans, and then sections and elevations. I then make sections pure drawing to edid them as i please. Save the project exit. When i ope...
  • 1651 Views
  • 3 replies
  • 0 likes
How to create a Non-printable layer
Hi, I have made a search but could not find any topic fort his: How do I create a non-printable layer? Up to now I have been hiding layers that I do not want to print. Any help would be much appreciated.
  • 5862 Views
  • 11 replies
  • 0 likes
Measuring slab Perimeter
Did a search and surprisingly nothing though I thought this was covered before. But anyway, does anybody know if it's possible to measure a slab perimeter (or a couple of walls for that matter)? I tried the zone tool hoping (remembering something), b...
  • 4672 Views
  • 6 replies
  • 0 likes
Text Justification
I'm trying to have some multi-lined text be able to be justified (within the block - if that makes any sense), and I can't find the setting. If I use the anchor option from DEFINE STYLE name font_family, size, anchor, face_code I just get the... anch...
  • 1856 Views
  • 2 replies
  • 0 likes
Images and Ghost Stories
I would like to place a scanned sketch on a "layout" story in order to draft over it. I have place the image as a figure, but the image/figure only shows as a placeholder on other stories. ...any help? Thanks
  • 990 Views
  • 1 replies
  • 0 likes
Editing .jpg textures - causes corruption in objects
I have tried editing the supplied .jpg files for textures to modify their colors in two different image editing programs. When assigning the texture in the Attribute Materials Manager, all my Objects Online objects in the drawing get really corrupted...
  • 807 Views
  • 0 replies
  • 0 likes
vertical wood siding
Hello, I can not seem to figure out how to create a vertical wood siding wall element. I have plenty of horizontal, but no vertical? Any help would be greatly appreciated. Peter
