Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 4982 Views
  • 121 replies
  • 13 likes
Survey follow-up – Door/Window Detail Level
Dear Community, Many of you took part in our recent survey on “Detail Levels of doors and windows on a single drawing”: https://community.Graphisoft.com/t5/Document-Visualize-forum/Doors-amp-Windows-Detail-Levels-within-a-single-drawing-1-minute/m-p/...
Purging unwanted layers using attribute manager
A Layer cannot be purged if there are any elements on it. Sometimes (by mistake), elements can be placed on a layer that will later require purging. This can occur in any of the possible views (plan, section or detail). To hunt down the offending ele...
Fills show through text
Hello - I have put some fills on my floor plan to indicate different flooring patterns. I am just using "simple drafting fills" On my text I have set to have an opaque background. This shows shows properly in ArchiCAD, however, when I import it into ...
Anonymous by Not applicable
  • 1543 Views
  • 2 replies
  • 0 likes
ArchiCAD 9 Hotfix-3 is now available
Dear ArchiCAD-Talkers, The third hotfix patch (build 2045) for ArchiCAD 9 is now available. Go to the 'Help' menu of ArchiCAD 9 and click on the command 'Check for updates...' This patch can be applied to all previous versions of ArchiCAD 9. For more...
REQUEST ("ANCESTRY_INFO",...
Can anyone tell me in which circumstances / environment /context objects do contain ancestry informations? This can not mean the subtypes definition in the editing dialog, isn't it? Does this mean the connection between elements and labels/markers? I...
Cannot detach section in AC9???
I've only recently upgraded to AC9... I just realised I cannot detach a section!!!! I must be missing something. I searched for 15 minutes on the ArchiCAD help site! Agggh Can someone enlighten me?
  • 1670 Views
  • 1 replies
  • 0 likes
Material - General
I want to make a wall surface with different material, and top is General, but why there are two different color shown in the same project in 3D? Could anyone tell me how to fix it up EY
  • 2490 Views
  • 5 replies
  • 0 likes
LIBRARY PART: CLOUD RECTANGULAR
There once was a time when the cloud was stretchy. What happened? I can't even change the parameters! What's up with that? Can you let me in on the secret?
  • 1628 Views
  • 2 replies
  • 0 likes
Monitor color fading
Since upgrading my hardware from a Mac G4 cube to a G5, I have noticed the colors in my floor plan views fading after working with the file for a time. 3-D work appears fine, but 2-D stuff is faded (reds turn a pastel color, etc.), and fill do not di...
  • 1300 Views
  • 1 replies
  • 0 likes
CadImage Wallbuilder-Wall Accessory
This is directed to anyone using Cadimage's WallBuilder. A basic question, but not knowing is a time waste. How do you "save" your customized wall settings/types? I've tried using favorites... no dice. Emailed Cadimage, but haven't heard back. Anyone...
