Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 7531 Views
  • 126 replies
  • 16 likes
Subtype functions/handlers
Hello, Is there somewhere a list of GDL subtypes with a description of the special functions or handlers associated with some of those subtypes ? We all know what functions are associated with the "Opening" subtypes Door(Wall), Window(Wall), Skylight...
Anonymous by Not applicable
  • 2566 Views
  • 4 replies
  • 0 likes
text to favorites
we have a series of general notes that need to appear on our plans & have noticed that can only save labels to favorites. When we try text, it only saves settings, not the actual note. Is there a way around this?
  • 2706 Views
  • 4 replies
  • 0 likes
Reflected Ceiling Plans
Hello, I was wondering what most users are doing to create reflected ceiling plans. Do you create a new story to house the ceiling objects or just use layers and combinations to properly display the ceiling? Also do you place slabs for the ceiling or...
  • 4915 Views
  • 7 replies
  • 0 likes
AC9 - Place all loaded objects automatically?
I recall a menu command from previous versions of ArchiCAD that would place all loaded library objects into a floor plan. We're going through a big effort archiving projects, and I thought this would be a good opportunity to identify project specific...
  • 2024 Views
  • 3 replies
  • 0 likes
plot maker is awful
plot maker is the most awful program.... do i have to use it? is there something else... it's so frastrating and slow i've spent half my time setup drawings in plot maker, some times more time then to do the archicad drawing.. the commands do work th...
  • 11478 Views
  • 20 replies
  • 0 likes
ArchiCAD version history?
Does anyone have a more or less complete ArchiCAD version history? I looked through Graphisoft but i could not find a release history or anything of the sort. Thank you very much
  • 5831 Views
  • 3 replies
  • 0 likes
Which way is 'L' and 'R' in wido_orientation
Hi all I am doing a door schedule with home made doors, it works great with one small catch. I am getting Left hand doors when they are right handed and vice-versa. Could someone please clarify for me, in case I am trying to fix something which is no...
  • 1441 Views
  • 1 replies
  • 0 likes
Door Labels in AC 9
I have been trying to use the doors found in the AC 9 library and with the Builder Dimension option. Can the dimension label be easily moved to be more out of the way? (like you can with dimensions text). And why do some of the labels read upside dow...
  • 8851 Views
  • 9 replies
  • 0 likes
Label tool w/ custom label
Hello I was testing the label tool using one of the custom labels, specifically the "Label Wall" label, supplied in the AC library and discovered that it doesn't work as I expected. I assumed it was supposed to display the thickness and fills of a wa...
  • 9741 Views
  • 10 replies
  • 0 likes
