Design forum
Forum Posts
San Diego Firestorm 2003
As far as I know: Fire started when a Hunter lit a signal fire so that his buddies could find him. This was in the back woods area of Ramona, from there the Santa Ana (50 MPH winds + ) pushed the fire all across the back country into various resident...
Intersection Groups
My Intersection Group setting in the layer dialog will not save. When I reopen ArchiCAD all the layers are reset to Intersection group "1". I have installed build 6392 which I read was supposted to fix the problem but still no luck. Any ideas? Thank ...
WIBU Drivers
For those on OSX, there is a new version of the WIBU key to try out - 4.0.0a available at WIBU's site. I'm using it on 10.3 client connected to a 10.2.8 server still running the 3.3.1 version of the WIBU key. All seems to be fine.
MarkG by Newcomer
  • 3840 Views
  • 0 replies
  • 0 likes
[hint] PM 3.1 - Numbering Drawings with the NCS standard
Thought I would post this rather obvious hint, but it may be useful to others. The default way that the new Plotmaker auto-numbers drawings is similar to how it does sheets - the order the drawings are placed in the list as seen in the Navigator dete...
MarkG by Newcomer
  • 3769 Views
  • 0 replies
  • 0 likes
Elevator library part
I'm a newbie to AC from Vectorworks. I was wondering how to create or use the elevator part so that its door breaks my wall like other window and doors. I don't want to use the wall option. By the way great job on the forum . I did not join architalk...
Ola by Newcomer
  • 14907 Views
  • 6 replies
  • 0 likes
Etiquette
Dear Talkers, PLEASE follow the Etiquette: - use the username known from the old Talk or your real name - put your location in the Profile; in the case of US locations, please put also US at the end - if you want to change your username, contact the ...
Djordje by Contributor
  • 20314 Views
  • 17 replies
  • 0 likes
Roof Surfacer AC 7
When I anoint the roof on both sides of a ridge with the standing seam--AC 7 Library_Add on Library_Roof accessory_roof_surfacer, I'm unable to convince the patterns to line up, i.e. "mirror". Is there a fix-it that anyone has discovered? Thanks, Wal...
Welcome!
Dear Archi-Talkers, Welcome to the renewed discussion forum of the ArchiCAD user community. As default structure for the new forum we created the following main categories: - General Discussions: here you can share your opinion with other users about...
