Design forum
Forum Posts
Tangent to two circles
While we're waiting for the Magic-Addon package, including the option to click on two arcs and automatically create the tangent, we can pay some humble homage to the Greeks... Draw the two circles (or arcs) 1a) From the centres of each circle constru...
Anonymous by Not applicable
  • 5671 Views
  • 0 replies
  • 0 likes
Need help drawing complex wall segment
I am new to ArchiCAD. I'd like to model a composite wall segment consisting of three layers... basically, 2 concrete walls with an insulation layer between. But there's another twist. The concrete segments are "keyed" so that they lock together. Wall...
  • 10597 Views
  • 6 replies
  • 0 likes
Stretchy angle hotspots in 2D
I am a tad confused about how the angled 2D moving hotspots work. After reading the manual about 100 times and randomly putting in numbers i got them to work but I have a few questions. 1. in the manual it states you need four points then they only s...
  • 5968 Views
  • 3 replies
  • 0 likes
Showing dashed in section what's beyond the cut
Glad that did the trick, Michele. The tip that I learned this from was on the old list on October 10 - thanks again Djordje and Link - this belongs in the Tips section: http://www.escribe.com/software/archicadtalk/m34966.html http://www.escribe.com/s...
Screening
Does anyone have any ideas/suggestions for simulating screening in elevation view? Partially hide what's behind? Thanks, Steve
Can't Create Line Tangent To Two Circles
In 2D, how do I create a line that is tangent to two circles? I can get the second endpoint tangent to the second circle, then reposition the first endpoint tangent to the first circle, but this makes the second point's angle different, therefore it ...
  • 17049 Views
  • 18 replies
  • 0 likes
Showing dashed in section what's beyond the cut plan
I have a slab with a hole cut thru it and I want a section view to show me the hole thru the slab as a dashed line. Is this possible? And if not, why not ? It isn't a library part, just a slab with a hole in it. Thanks, Michele
  • 8052 Views
  • 5 replies
  • 0 likes
Looking for metal building parts and pieces
Is there any 3rd party that sell complete metal building, structural components? (Tapered columns, tapered spandrel beams, purlins, etc.) I mean the all parts of an entire building, not just individual pieces. If so where would it be located. I do no...
  • 2708 Views
  • 2 replies
  • 0 likes
Offsetting spline possible?
This seems like a pretty basic thing, but I can't figure out how to offset a spline. Trying to create a "snaky" walkway. (Offset tool and magic wand don't seem to work with this.) Thanks.
Didn't find the answer? Start a new discussion
Labels
