Design forum
Forum Posts
Auto-text within notes in ArchiCAD
Okay, Plotmaker assigns a code to each quickview placed in Plotmaker. Then it uses a code to assign different forms of autotext. A code, like , followed by the code for the quickview, which looks something like . If you copy that code to ArchiCAD, wh...
Anonymous by Not applicable
  • 6413 Views
  • 0 replies
  • 0 likes
crashing in section elevation window.
I am working on a really big house, and from time to time for reasons I still can't find, it crashes, or more accurately hangs indefinately. I quit archicad and reopen it and up comes the temporary file prompt, I accept, then the file opens and the w...
  • 6403 Views
  • 5 replies
  • 0 likes
Context Menu Shortcut Keys in 8.1
I'm trying to get used to 8.1, and there seem to be some great improvements, but there are a couple of issues I need help with. I'm used to removing a marquee by doing a right click, (Windows) and pressing 'Q'. This doesn't work with 8.1, and I can't...
  • 14893 Views
  • 14 replies
  • 0 likes
check a file in?
Sometimes when I try to open a file, I get a message telling me that the file is already in use. I am not networked to any computer. How do I check this file in so I can use it? Thanks, Lori
  • 3937 Views
  • 1 replies
  • 0 likes
Text That Doesn't Scale?
I have some signs that I am detailing that have text on them, but when I set the scale for dimensioning, the text size changes. How can I make that text ignore the scale and just stay the same size?
  • 7023 Views
  • 5 replies
  • 0 likes
file in a loop
It seems that my file is in some sort of a loop and I can't open it. What can I do to retrieve the information? thanks, Lori
  • 5843 Views
  • 5 replies
  • 0 likes
empty fill
How the heck do I make an empty fill? I've tried to copy an empty fill and I get color that I have to change to white and I don't want white. I've looked in the tutorial (v 7 has something on it) No luck on empty fills. Please help! THIS is real frus...
  • 7266 Views
  • 6 replies
  • 0 likes
Nominal values in door marker - how?
I am trying to get a result similar to what was in ver. 7.0 - I mean when I set "nominal" values I would like them to display in the marker - but when setting it in almost all doors from 8.0 (or 8.1) library I get it wrong. It is probably beacuse the...
AC Version & Library Transition
Please forgive me--I know this has been discussed in the past, but a search of the forum didn't turn up any answers. I started a project in AC 8v3. Now I want to work in 8.1. What is the correct procedure for making the transition and avoiding librar...
Didn't find the answer? Start a new discussion
Labels
