Window distance from floor
Is there anyway within GDL to script in the height that the window would be off of the floor? Or to the top of the window. Maybe a global parameter that I'm not finding?!?!?!?!
I have been unable to use the roof wizard for quite some time now (since 8.0r2) I keep getting the error that the library object "Rafter" cannot be found in the loaded libraries. I've reinstalled libraries, AC etc. many time with the same result. Is ...
I've been using the dimension markers to show the Element ID's of doors and windows on plans, and loving it for the most part. The only problem I seem to be having is that when I match a window with the eyedropper, it does not pick up the Element ID ...
Hello Talkers, Problem: When I want to show different alternatives of walls or columns, even though each alternative are on separate layers, and of course alternative 1 is off when alternative 2 is on, I find that when the "on" wall crosses over wher...
Dwight wrote:Does anyone else on this forum experience a file preview that looks like a quicktime movie playbar in the preview column when selecting a library object [ .gsm]???? Yes I had this with the previous version of the GDL web plugin when usin...
I want to change the attributes (pen color, styles,etc.) of the original Archicad Library parts to adapt it at our drawing standards and not to have to change it manually every time, but I don't know how to do it to guarantee futures upgrades of libr...
I know this has been discussed before, but maybe just in terms of the wish list--anyway, I couldn't find anything searching. What's the best way to handle a 2-story window so it shows properly on both stories with a minimum af messy workarounds?
I always have a dozen or so "Missing Objects" when loading my libraries (Bolt 2, Scotia, Interior Reveal 2, etc.) They are objects I've never used. Is there a way to track down which library they are from and discover why they are "missing"?
Any one experience this before. For some reason in 8.1 i can't get clean intersections to work properly. Never have had this problem before. If i have a wall on Layer A-WALL-EXTR-FULL &/or A-WALL EXTR-LOW the walls look great and have the proper clea...
How do I modfiy the roof label to show the pitch in the "3:12" format? It would also be nice to have the arrow show the pitch direction. I obviously have no gdl experience. I figure I need to look for all the assiciative labels before I "dumb draft" ...
User | Count |
23 | |
8 | |
7 | |
6 | |
6 |
