Design forum
Forum Posts
Porting ArchiCAD to Linux
As head of sales for a Linux based company, Lycoris, I get questions from a large cross section of users. I know that we have several architects that choose to use Desktop/LX because it is simple, clean, effective, and efficient. I've been asked if w...
Anonymous by Not applicable
  • 8708 Views
  • 5 replies
  • 0 likes
looooong wait for AC 8 to power up
Hi, This is more a comment than anything else... Our central server (which all files are on) is under repair today, so everyone copied the files they needed to their own computer. I'm running OS 10.3 & AC 8v3 on a dual 1Ghz G4 and I have to wait abou...
  • 14240 Views
  • 16 replies
  • 0 likes
Save / Backup anomalies
I've encoutered some inconsistencies when saving a *.pln file and wonder if anyone else has encountered this problem. When working on a *.pln file, I will save my progress as normal (with Save, not Save As...). On occasion, when I go to Save again, t...
  • 4721 Views
  • 3 replies
  • 0 likes
Stopping AC mid calculation?
Hello - This is probably an easy one. How do you stop AC from calculating in the 3D window, section/elevation tool and photorendering window? For example: you start a photorendering and then realize you forgot to adjust the sun angle so you want to s...
TDabney by Participant
  • 18593 Views
  • 19 replies
  • 0 likes
I started this with the label tool but then .....
I am recreating a symbol template in 8 – it is a section elevation window. Of course one cannot put a wall in it. Who cares about a template probably just idiots like myself doing construction drawings. I have to question this. How it is possible tha...
  • 5172 Views
  • 3 replies
  • 0 likes
POLY2_B background fill
I have two objects that use POLY2_B which allow the user to choose the colour of the background fill. What is weird is that one object works as expected whereas the other doesn't. I can't see any difference between the 2d scripts. The only thing that...
-1 pen
What is the -1 pen used for? It is listed after the Ø pen with a monitor symbol. Stig Bengtsson
Text from a numeric value
I want to print a report of a library part ( actually for a door schedule). I need to insert a dimension value into a text string. Im not sure if this is possible. Any ideas?
Layer combo to Navigator
Jus am just starting with 8 and I am disappointed that the layer combinations do not appear in the navigator. What a pity. This was one of the most important features I have expected, to graphically connect the layer dialogue and the navigator.
  • 5313 Views
  • 3 replies
  • 0 likes
Didn't find the answer? Start a new discussion
Labels
