WIBU Drivers
For those on OSX, there is a new version of the WIBU key to try out - 4.0.0a available at WIBU's site. I'm using it on 10.3 client connected to a 10.2.8 server still running the 3.3.1 version of the WIBU key. All seems to be fine.
Thought I would post this rather obvious hint, but it may be useful to others. The default way that the new Plotmaker auto-numbers drawings is similar to how it does sheets - the order the drawings are placed in the list as seen in the Navigator dete...
I'm a newbie to AC from Vectorworks. I was wondering how to create or use the elevator part so that its door breaks my wall like other window and doors. I don't want to use the wall option. By the way great job on the forum . I did not join architalk...
Does this really work?
Dear Talkers, PLEASE follow the Etiquette: - use the username known from the old Talk or your real name - put your location in the Profile; in the case of US locations, please put also US at the end - if you want to change your username, contact the ...
When I anoint the roof on both sides of a ridge with the standing seam--AC 7 Library_Add on Library_Roof accessory_roof_surfacer, I'm unable to convince the patterns to line up, i.e. "mirror". Is there a fix-it that anyone has discovered? Thanks, Wal...
Dear Archi-Talkers, Welcome to the renewed discussion forum of the ArchiCAD user community. As default structure for the new forum we created the following main categories: - General Discussions: here you can share your opinion with other users about...
User | Count |
23 | |
10 | |
10 | |
9 | |
6 |
