Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 5208 Views
  • 121 replies
  • 13 likes
stone fills
I find the standard list of fill s limited and need a fill that represents sonework for my elevations. Is there anywhere I can download a fill?
Anonymous by Not applicable
  • 5803 Views
  • 2 replies
  • 0 likes
invisible elements
hi all is there a possibility with gdl to define elements who are just visible on the screen? if you print it... they are invisible... something like a hotspot or a camera in archicad... thanx for your tips! xa-4
  • 6489 Views
  • 4 replies
  • 0 likes
Stairmaker
I know that this has probably been asked before, but I couldn't seem to find it. Can you now trim a wall to the bottom of a stair (in my case a curved stair) in 8.1? If not, what is the best way to do this? Thanks, Don Lee
  • 6043 Views
  • 5 replies
  • 0 likes
Help
More than likely I say this is an easy fix. Ex #1----LogsHigh = int((HLH_RoHt + 0'-3")/HLH_log_sh) Ex #2----parameters HLH_Lo2 = str("%", LogsHigh+1) What I'm doing is taking an int from Ex #1 and converting it to a string and the value I'm receiving...
Red by Enthusiast
  • 4488 Views
  • 2 replies
  • 0 likes
Scale Retention In Cloned Folders
Some investigation... As I understand cloned folders, the idea is to have a complete, dynamic view set folder containing, for example, all the Section/Elevations, so as you create new windows you don't have to manually create views. I should be able ...
Library parts wanted
Hi all I was wondering if anyone has some 3d objects that I could have or get from somewhere. I have looked all over the net but nothing has really taken my fancies. Objects I was looking for are : Nice looking Palm Tree 3d Text (where you can stretc...
  • 14182 Views
  • 10 replies
  • 0 likes
Key Shortcuts- from 8 to 8.1
I looked and could not find this toppic. When we changed from AC7 to 8 the file u save in the Keyboard Shortcuts was easily copied into the new AC8 folder- I now need to do the same to 8.1 and cant find the file- does this make sense, does anyone und...
  • 8080 Views
  • 8 replies
  • 0 likes
Opem two stories at the same time
In my opinion this is a shortcoming. To many times I have to see an area located on a different story and different place. Sooner or later this efficiency dating back to day one will have to be addressed.
  • 5581 Views
  • 3 replies
  • 0 likes
[tip]How to figure out which views are linked to which PLN
Our template LBK file has views linked to different PLNs/PLPs. One is a template PLN and another is a PLN that contains commonly used/rarely changed details. These details generally show up in every job we do. We usually leave the views linked to the...
  • 7225 Views
  • 1 replies
  • 0 likes
Windows and glass position
I want to put in windows that have the glass located 1" from the frame instead of centered in the frame. Is there a window object in Archicad that can do this or do I have to create a new object? Thanks for any help, MIchele
  • 3770 Views
  • 2 replies
  • 0 likes
