Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 5005 Views
  • 121 replies
  • 13 likes
Survey follow-up – Door/Window Detail Level
Dear Community, Many of you took part in our recent survey on “Detail Levels of doors and windows on a single drawing”: https://community.Graphisoft.com/t5/Document-Visualize-forum/Doors-amp-Windows-Detail-Levels-within-a-single-drawing-1-minute/m-p/...
New & Old Objects not showing up in Object selection are
Ok here is a good one, I am using 8.1 and I have not yet loaded 8.1 library.... But when I was looking at my existing library parts, I noticed that some of the icons did not show up in the selection window... Not sure why this is, I tried to create a...
DVH by Participant
  • 5224 Views
  • 2 replies
  • 0 likes
mapping and modeling
this is a pic of the 3D model sign.........and when I go to 'image' and 'photorender projection'...........the mapped logo moves off center and the materials (ie, supposed to be a dark stone base) don't show up. any suggestions? (see model sign 2 for...
Anonymous by Not applicable
  • 3293 Views
  • 0 replies
  • 0 likes
use of viewsets in mid operation
i have just discovered that i cannot use saved views in my viewsets to navigate around the building whilst in mid-operation: i.e. i was dragging a copy of a load of useful stuff from one stair core to another. as they are spread out on plan, i decide...
[OT] It's been fun...
Well, just a wee little note to say adios amigos! Tomorrow is my last day and will probably be spent cleaning stuff up for my successor (he will probably make his presence know here soon). I've enjoyed emailing and posting on AC-Talk these past two y...
  • 5851 Views
  • 3 replies
  • 0 likes
CAD2004
now ive upgraded my architectural desktop 3.3 to 2004 the merge function does not seam to work. Ive my plans in CAD where i was about to merge into archicad8 but it doesnt bring up the window that it normally brings up. any ideas?
  • 9612 Views
  • 8 replies
  • 0 likes
Wall building
In ADT and especially revit there is a lovely function to custom design the type of wall im building. I can build up a wall in layers saying what it is, how thick it is, building from the inside to the final render on the outside. e.g. block, insil, ...
  • 4029 Views
  • 2 replies
  • 0 likes
Window settings...
Hello all, I have a W Direct Glazed window and I would like to know what some of the settings are for: Under "Parameters>Options" I see a setting called "Align to Door/Window on Side" from the description I can just about figure out what this does. M...
rgarand by Participant
  • 4481 Views
  • 2 replies
  • 0 likes
