Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 9187 Views
  • 127 replies
  • 18 likes
Door Markers
Question. I am working on a file for another architect who uses 7. I am using 8r2. I had him create a .pla so that I would have the correct library parts. This has worked fine, except... the door markers will not show up. Even if I put in a version 8...
Anonymous by Not applicable
  • 4944 Views
  • 3 replies
  • 0 likes
Alt-x ALt-y Alt-a and Alt-R constraints in 8.1
What happened to Alt-x ALt-y Alt-a and Alt-R constraints in 8.1? They don't seem to work, can I get them back? And also is the Shift selection method in any tool that used to be until 7.0 version back? BEst regards, António Pina
  • 8180 Views
  • 5 replies
  • 0 likes
Hey man....where's my brick sills?
AC8.1 Trying to figure out this fancy smancy brick sill detail feature. I'm doing some rowlock window sill details. Can't seem to locate or make it work. Am I missing something.?
  • 5015 Views
  • 2 replies
  • 0 likes
modules
horror of horrors, i have opened a file up to find that it is a hotlink of itself. it must have been when i used the thick marquee to export all stories as a module and now it seems each story is a module. If i delete the module in the hotlink list t...
  • 5060 Views
  • 4 replies
  • 0 likes
truss maker
I've just tried Trussmaker for the first time. I'd like to create plumb cut rafter tails and trim off some unwanted parts of a truss. Besides the Edit Truss commands there any way to notch or otherwise alter a truss? The trusses that that Trussmaker ...
  • 8707 Views
  • 2 replies
  • 0 likes
Library
At the beginning of my relation with ArchiCAD after listening to the sales pitch of the GS salesman I have asked this question: Jus for long this library parts will remain compatible with the program. The answer was : As long as there will be ArchiCA...
  • 3386 Views
  • 0 replies
  • 0 likes
Eydropper w/o Changing Object Type
When creating doors and windows, is there a way to shortcut the process? Example: You create a window from the standard library using, say, the W1 Casement. You get all the parameters set and place (takes a good 5 minutes if working from scratch). Ne...
