Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 5508 Views
  • 121 replies
  • 13 likes
Cannot Select Autotext
There are two pieces of auto text that I cannot select in my teamwork file. Not sure why. Quick Select is on, all layers are on and unlocked. Text is "#LayID," if that means anything. I am not sure if it is text or a label, but using the Find and Sel...
Anonymous by Not applicable
  • 212 Views
  • 1 replies
  • 0 likes
Elevators and Stories: a divorce waiting to happen.
Elevator objects in the main libraries are great, we usually use them, until we reach a project where we have to use different Z heights for their doors for a multitude of reasons. For instance, if we have different buildings with different heights o...
  • 577 Views
  • 2 replies
  • 0 likes
Split a wall through a roof.
I need to split a wall through a roof, so I have to separates walls one underneath the roof and other above the roof to applying different materials. Is it that possible?
  • 528 Views
  • 6 replies
  • 0 likes
Objects not appearing in plan view
I have duplicated and dragged a set of objects (morphs) in section view and want to drag them again in plan view but they do not appear in plan view. They appear in 3D so I know they are there. Why won't they appear in plan view? Thanks for input.
  • 511 Views
  • 2 replies
  • 0 likes
Opening Lines
Hello, I have an object that I need to put opening lines on...however I have no idea what the best way to do this is. (The height and width changes) What is the best way of doing this?
JGoode by Advocate
  • 231 Views
  • 2 replies
  • 0 likes
Tick a boolean, turn another off
Hello, I have 3 different tick-boxes. When I tick one I want the other 2 to untick and visa versa. However when I tick 1 and then tick another, it doesn't seem to swap due to the first tick-box being coded first in my script. Is there a way around th...
JGoode by Advocate
  • 231 Views
  • 2 replies
  • 0 likes
Resolved! Hotlinks Breaking
Hi all, I have just found in one of my models that the majority of hotlinks have become embedded into the host file. It is a multi story building in which the modules were inserted into one story, then copied onto the other stories that have the same...
BIM Server & BIMcloud 21 Update 6002 Released
Dear All, Today we have started to release the next BIM Server and BIMcloud 21 Updates. As you may already know, starting from version 21 Server Updates have become independent from ARCHICAD Updates. This means that releasing and installing them can ...
