Adjustable handle/node using GDL scripting.
Hello, I am new to GDL scripting, I was wondering if anybody could assist me with adding an adjustable handle/node to a GDL object? Any assistance would be greatly appreciated! Cheers, Jarrod
To whom it may concern, Is it possible to have 1c/230 external wall or 2c/250 external wall and split it into 4 section and join them together? Waiting for your reply and have a great day. Cheers, Chris
hi all - We have created a custom profile wall that consists of 7/8" corrugated metal cladding. This wall is a skin to a regular AC wall. We want to create an empty opening in this wall that corresponds with the steel bucket window in the regular wal...
I'm only 2 months into Archicad. I have increased a the uncut line pen for a 6" block sitting on a 12" block. I did this to make it pop in the foundation plan. However it also changes it in the elevation which is not helpful. How do I make a lineweig...
Hola. I just started to use ArchiCAD and i have couple of problems. Hope that someone can help me. >Where can I change to remove these (i guess construction) lines when I export images? These red lines on doors and windows, green on roof, etc. >How t...
I can't seem to work out why the calculations don't seem to be working as I think I might have used the same sort of calculation previously. Is there any reason why it is not changing the object at all?
What is the recommended limit for polycount for something like a Toilet or basin? is 2000 too high?
Hi, I'm having trouble with the tracker - it shows the distance for slabs as the distance from project zero and after I do the first click then it shows the distance from the last point. It doesn't have this problem with walls though.... Thanks Naomi
Hello everyone! This door helps user to model slide door, setting multiple leaves. More relevant information you can find here: http://noletoblog.blogspot.com.br/2017/08/multislide-door-para-archicad-1920-e-21.html Also there is a video showing brief...
Back saving from ARCHICAD 20 to ARCHICAD 19 I am having an issue with Library objects not showing in ArchiCAD 19 after back saving from an ArchiCAD 20 file. * (I'm not sure if it's relevant, although I'm switching from a Mac to Windows as well). The ...
User | Count |
28 | |
8 | |
7 | |
7 | |
6 |
