Design forum
Forum Posts
2-digit values for stories level
I set up values to 2 decimal places in the ARCHICAD/PROJECT PREFERENCES; but look like it is not showing up in the elevation levels. I want to set up the Height to Next as 2.65. Looks like it has round it off to 2.7.
Llian by Enthusiast
  • 1515 Views
  • 5 replies
  • 0 likes
Dual IES Light Object
I have been integrating the GS IES Light into some objects, so now I have 2D, 3D and Light all in one object... I was wondering if anyone has made a dual IES Lights with the option to change the direction of each lamp. as per requirements of the imag...
door cure line
I have no problem with this until AC20...is there something new to get the door opening line? I have been going back and forth an older file that has the line but this is just not showing. Please help. I have reduced the resolution of the screenshot ...
Llian by Enthusiast
  • 895 Views
  • 3 replies
  • 0 likes
Exporting and importing object parameters
I have a range of electrical objects (+50), each time I make an addition I need to add a parameter manually. I wish there was a way to export that parameter or all parameters as an xml then import them into the next object along with it's values.
surface painter
Hello, does anybody know how to assign other surfaces to pointed areas. All is one slab.
Anonymous by Not applicable
  • 919 Views
  • 2 replies
  • 0 likes
Curved corner roof?
Hello, I have made this roof house in archicad. How can i place the gutter or something to retain water in archicad along the curved line? (left side of the picture) How is this roof called, with one slope but rounded, i can't find it on internet. Th...
  • 2353 Views
  • 5 replies
  • 0 likes
mac-rhinowip- beam tool
Hi I use mac book pro, macos sierra, rhinowip 5.4 whit archicad connection and archicad 20 int , all updates done. I try to repeate "parametric tower" example , "non-linear curve segments must be on the XY plane" warning !!when I use "beam tool" when...
  • 2190 Views
  • 3 replies
  • 0 likes
Archicad GH connection problem
I already installed archicad 20 and the latest version of GH then i installed Gh -archicad live connection 20 but i found no component of archicad in component bar but in archicad things go well I used windows 10 X64
  • 2698 Views
  • 4 replies
  • 0 likes
Missing door
I am not sure what has gone wrong...I started a new project using a previous project and now the door is not showing a curve opening line and showing 'Missing doors'...can someone please help me.
Llian by Enthusiast
  • 526 Views
  • 0 replies
  • 0 likes
Didn't find the answer? Start a new discussion
Labels
