Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 7528 Views
  • 126 replies
  • 16 likes
Adjustable handle/node using GDL scripting.
Hello, I am new to GDL scripting, I was wondering if anybody could assist me with adding an adjustable handle/node to a GDL object? Any assistance would be greatly appreciated! Cheers, Jarrod
Anonymous by Not applicable
  • 1552 Views
  • 5 replies
  • 0 likes
External Walls
To whom it may concern, Is it possible to have 1c/230 external wall or 2c/250 external wall and split it into 4 section and join them together? Waiting for your reply and have a great day. Cheers, Chris
  • 644 Views
  • 1 replies
  • 0 likes
empty opening in custom profile wall
hi all - We have created a custom profile wall that consists of 7/8" corrugated metal cladding. This wall is a skin to a regular AC wall. We want to create an empty opening in this wall that corresponds with the steel bucket window in the regular wal...
jkershaw by Enthusiast
  • 2209 Views
  • 7 replies
  • 0 likes
How do I increase lineweights in plan and not elevation
I'm only 2 months into Archicad. I have increased a the uncut line pen for a 6" block sitting on a 12" block. I did this to make it pop in the foundation plan. However it also changes it in the elevation which is not helpful. How do I make a lineweig...
  • 1137 Views
  • 4 replies
  • 0 likes
New user - couple of questions
Hola. I just started to use ArchiCAD and i have couple of problems. Hope that someone can help me. >Where can I change to remove these (i guess construction) lines when I export images? These red lines on doors and windows, green on roof, etc. >How t...
  • 1587 Views
  • 3 replies
  • 0 likes
Why doesn't my 2D poly calculation work?
I can't seem to work out why the calculations don't seem to be working as I think I might have used the same sort of calculation previously. Is there any reason why it is not changing the object at all?
JGoode by Advocate
  • 1603 Views
  • 8 replies
  • 0 likes
Tracker - Coordinate problems
Hi, I'm having trouble with the tracker - it shows the distance for slabs as the distance from project zero and after I do the first click then it shows the distance from the last point. It doesn't have this problem with walls though.... Thanks Naomi
ngoldie by Participant
  • 1020 Views
  • 2 replies
  • 0 likes
MultiSlide Door for ArchiCAD
Hello everyone! This door helps user to model slide door, setting multiple leaves. More relevant information you can find here: http://noletoblog.blogspot.com.br/2017/08/multislide-door-para-archicad-1920-e-21.html Also there is a video showing brief...
