Design forum
Forum Posts
trace is offsetting floors
trace is offsetting my floors and it is driving me nuts. I reset the 0,0,0 and have been trying to set all floors with this beginning, but trace doesn't like it.. and keeps misaligning my floor/walls/roof..... is there a setting that offsets trace so...
Anonymous by Not applicable
  • 687 Views
  • 1 replies
  • 0 likes
Layer priorities
I find that if I change the priority of a layer, as per attached file where "partitions" have been changed from "1" to "6" and then close the Layers window, when I next reopen the window I find that the "6" (or whatever number I entered) has reverted...
  • 1012 Views
  • 1 replies
  • 0 likes
Roof Label
If anyone can find the time, have a look at this label - it works in the plan window and differently in the elevation window -- however I cannot get it to sense the direction of the roof plane -- I have put in a flip command but think it would be muc...
RandyC by Booster
  • 3438 Views
  • 8 replies
  • 0 likes
How to retrieve an auto save.. help
I accidently closed a file without saving (thinking it was just the rendering window). Now I have lost an hours worth of detailed work unless I can extract the auto save that much be there somewhere. Any help is appreciated.
Wall End Tool not working
I've been having this issue a lot in this model and can't figure out what the issue is. I have this freestanding wall (wall is complex profile with central reference line) and on each end I put a wall end but it keeps kicking the wall end off to the ...
  • 2396 Views
  • 3 replies
  • 0 likes
Cut plane behaviour
Sometimes AC doesn't behave as expected. I'm using AC18 for this project and have the cut plane at it's default 1150 mm above my current floor. I create a 2072 high opening in a wall. This is well above the cutting plane, isn't it? So why does my sta...
KeesW by Enthusiast
  • 689 Views
  • 1 replies
  • 0 likes
Changing room dimensions?
Hi. Im new to building design and Archicad and I am struggling to find a simple way to change room dimensions. Most programs I have used you simply click on a wall then click on the dimension area and type what the dimension you need and the walls al...
  • 2864 Views
  • 4 replies
  • 0 likes
Joining Walls
I got two different types of walls which meet each other. The problem is that there is a bold black line dividing the two walls. I want this line to go away where the walls meet. I could change the composite wall edge lines because the materials line...
Window Wall Contour Lines
I am trying to set up my 3D windows to look a certain way in plan view. I almost have what I am looking for, but the Window Wall Contour Lines are in the way. The image I attached shows the problem and where the settings are to adjust the lines which...
Didn't find the answer? Start a new discussion
Labels
